2000 Expedition 5.4 throwing codes for all 4 o2 sensors. Sensors already replaced and still throwing code
giuliandi
We replaced all 4 o2 sensors and immediately got a pending fault (later confirmed) again. Also engine is idling rough and has a little shake. Does someone know what this could be? No other codes but these.
jr1under
Aiken, SC
According to the OBD SysOp manual, those faults happening immediately after starting the engine indicate a voltage problem. As it's occurring on all four circuits, maybe there's a common power source to blame.
Staren72
I have a similar problem, but just for one. Replace all four but one sensor keeps fouling up. Any ideas for that?
jr1under
Aiken, SC
Summarizing some of what was posted above...
If only one sensor is failing and it's new then the sensor and fuse are not the problem. If it happens right after startup, there's a voltage problem which might be caused by damage to the wiring or harness plug pins for that sensor.
