2019 a/c question
guzzi71
Fl
2019 exp limited
The a/c shuts down after driving at hwy speeds. Blows warm air with no response from the climate controls. Just had it at the shop and he let it run for some time and said everything looks good,but he didn't take it up to hwy speeds. Tells me that it most likely needs either a software or a firmware update. This sounds very probable to me. If any of you have had a similar problem or can advise me on how to remedy this, please do. I'm really out of my depth here. Thank You very very much..
Guz
Hellwig
2019 exp limited
Guz
what's the DTC code(s)?
2019 exp limited
Guz
This MAY be the issue: https://static.nhtsa.gov/odi/tsbs/2022/MC-10209031-0001.pdf
G
guzzi71
Fl
Thank you for ypour response.
Hellwig, i do not know of DTC codes. I took it to the shop and this is what they told me.
99WhiteC5
This is very interesting and sounds very close to my symptoms. Do you think that this should be done at the Dealer? Or can this be done by someone who specializes in primarily a/c ?
Just want to thank you my friend's for your knowledge, you are the best and I will you know what I find out.
Guz
99WhiteC5
Guz
Florida has a lot of a/c specialists - but a dealer would have all the necessary equipment and access to this and any other TSB’s or special instructions from Ford.
Hellwig
2019 exp limited
Guz
Did you make any modification on anywhere electrically? Like Start/Stop eliminator? If you did, check the connectors.
G
guzzi71
Fl
Hellwig,
I don't know what has been done. We have only had the truck for 4 months and up until now it has been awesome. Really enjoy the vehicle and am a bit pissed and sad that problems are appearing so soon.
Thanks again for your knowledgeable suggestions.
Guz
G
guzzi71
Fl
Still waiting on our appt with Ford. Could I ask another question? Do you think that the drip drain may be air pressure at hwy speeds? Possibly preventing the water from draining the evaporator? Is this a possibility? Thank you sir.....guz
G
guzzi71
Fl
Welllll got the truck to do it and here's what I got. The a/c was blowing at ambient temp 81-82. Turned a/c off and heat on,the water poured out of the evaporator drain. Let it run for about 15 min on max heat,turned on the a/c still warm air. Same on the rear air. Turned off the vehicle for about 20 min restarted and.....still warm. When I start it tomorrow it will be fine can drive around 2+hrs fine. Get on the turnpike 20-30min warm ambient air????? Got appt on monday at ford, I guess I will see what they say. Thanks all...guz
Soliyou
OK
See this video. It may need a big surgery!
https://www.youtube.com/shorts/3vzAWE7zNaw
G
guzzi71
Fl
Yes have had my suspensions about thar also Thankfully it has a extended warranty that will absorb most of the cost.
techdude99
US
If all the pressures are good than I would agree the Evap temp sensor is probably the first thing I'd check. Strange that it's not throwing a code.
G
guzzi71
Fl
No code on the idiot lights in the cluster.
I guess we will hear later today or in the next few day's what ford has to say. Thanks for your input. Guz....
G
guzzi71
Fl
Problem solved. There WAS a leak in the evaporator.
So much for the first guy I took it to......... Thanks all, Guz
bmk1
yellville arkansas
How much was it to repair? Your issues sound similar to mine. I’m going to call later today and make an appt I guess..
