Largest tires that will fit stock FX4
Micah Z
WI
Anyone know the largest tire size that will fit on a stock 2019 Expedition XLT FX4? Without modifications and using the stock 18" FX4 wheels. What fits without rubbing? The Michelins that it came with measure about 31.5" diameter as-is. Also, I can't seem to figure out what the rim width is of the stock wheels or what the max width tire they accommodate. Anyone know?
sjwhiteley
Kentucky
There are a few threads on tire sizes, but don’t directly answer the question due to additional factors, such as lift, change in wheels, etc.
the wheel size is 18x8.5 with a +44mm offset. For reference, the 20s are same width with same offset. The 22s are 9.5 with same offset.
one of the issues with bigger tires, isn’t just the diameter (liner rubbing) is the width. At full lock, the tires are close to the upper control arm. You can test this, yourself and feel the clearance. Also, you can have someone slowly turn the steering wheel and watch the wheel in the wheel well to see how much clearance you have.
to me, it looks like you could go to nearly 33” diameter maybe a bit more (32.5 as noted above) and maybe a bit wider. As a reference, there is a thread or so discussing adding Raptor wheels and tires, which are massive in comparison, to get an idea where the rubbing is.
This maybe old news to some, here.
Fozzy
Riverton
I don’t know if this is normal for all Expys or just mine. I bought mine new and had the Ready Lift Put on day one. Installed 35x12.50x20’s and had to do some minor trimming. After 3500 miles the suspension must have settled in and I had to do more trimming. If it’s new I would leave a little room just Incase. Especially if you don’t want to trim your fenders.
Shaffer9
Ms
Thanks for the replies! Just bought a '19 FX4 and thinking about what we could stuff under there on the stock rims.
RANDAL CHAO
Orlando Florida
In tire shop right now. Here are the latest intel:
2020 Expy Limited FX4, RL 3/2, Raceline Mamda HD 20x9 +25mm
Tried several tire sizes:
Nitto Terra Grappler G2: 35x12.5x20 rubs (34.5"x12.5"), need to move front fender line about 1", doable, but too much hassle
Nitto Terra Grappler G2: 295/65/20 rubs (35.1"x11.8") , need to move front fender line about 1", doable but too much hassle
Nitto Ridge Grappler: 285/60/20 (33.7x11.5), very very minor trim when fulllock.
Update: Realigned fender felt liner, now no problem with 35/12.5/20 G2 Tires.
Cheers -R
MontExped18
Montana
Just wanted to double check to see if a set of winter tires I currently have will fit on my Expedition. I have a stock (no lift, no leveling kit) 2018 XLT 4x4. Tires are 285/60/18. Will they fit without any rubbing? Appreciate the help!!
Shaffer9
Ms
Yes should be fine, running 285-70r18 with no issue
MontExped18
Montana
From what I understood on here they would work without rubbing but the tire shop told me they would rub. Probably just want me to buy a new set.
Shaffer9
Ms
What is your stock tire size? 285/60/18 is not a large tire.
rawbaws
Wilmington NC
@Shaffer9 what was the 285/70/18 tire you had? Were you happy with it? Just bought a 19 xlt fx4 and don't want to lift it but want a big aggressive at tire that doesn't rub but each manufacturer size is slightly different. Which 285/70 did you go with on the stock 18 rims? Ty!
Pawpaw
Raceland, La.
'21 FX4 with BFG KO2's 275x70x18 on the factory wheels. One size up from stock and great for mild off roading and towing our camper. IMG_6227.JPG
rawbaws
Wilmington NC
'21 FX4 with BFG KO2's 275x70x18 on the factory wheels. One size up from stock and great for mild off roading and towing our camper. View attachment 81241
Looks sweet pretty much what I'm looking for. Was just curious what 285/70 tire @Shaffer9 Had on his. The 285 would be about 1/2" to 3/4" taller than 275 depending on brand. The new 285/70/18 falkens are a full 34" but bfgs are like 33.6". Just wondering which 285 he got with no rub. May just go with 275s to be safe. Yours looks like what I want
Pawpaw
Raceland, La.
@Pawpaw Do you have another 3/4" of room on your 275s or is 275 as big as you would go?
I wanted to be safe with the clearance since we tow a 8K pound camper. The 275mm width is just about factory width I had with the 275x65x18 stock tires. We get a lot of rain in Louisiana and I find the wider the tires the more chances of hydroplaning when hitting standing water. Tire height is 33.2 and they fill the wheelwells great at stock FX4 height. Not even close to rubbing and they still get decent fuel mileage for daily use. Stock wheels keep the tires inside the wheelwells and help contain road splash. I highly recommend this size if you do any towing or offroading.
