Bmac1955
Sorry, I omitted one important aspect. Hit the start button while both pedals are depressed. After 10 or so seconds remove foot from gas pedal and it will start.
That’s ridiculous. It would take them a matter of seconds to do it while doing the cam phasers. I just had mine done and it was $260 after tax.My local dealership quoted me 3 hours labor charge to replace thermostat, for a total of $567 excluding parts. I think it is insane.
They redesigned in 22 I believe it was. I have a 19 and it was getting over 230° engine temp and shutting down my AC. Plus 230 is just way too hot.What's wrong with the thermostat? It's my wife's Expedition and she's very cheap lol. Doubt she would do it unless there's a really good reason.
It's not really flooding. If you hold the gas pedal all the way to the floor while cranking the engine, it disables the injectors. This allows you to crank the engine for 3-5 seconds before removing your foot from the gas. That is enough to get a small amount of oil pressure built up and prevents a dry start for the cam phasers. You only need to do it on cold starts, like overnight. I've been doing it on my 5.4 Expedition for a couple of years now and it does work to reduce/eliminate the start up rattle.Would you explain cold start flooding please and also why.
It's not really flooding. If you hold the gas pedal all the way to the floor while cranking the engine, it disables the injectors. This allows you to crank the engine for 3-5 seconds before removing your foot from the gas. That is enough to get a small amount of oil pressure built up and prevents a dry start for the cam phasers. You only need to do it on cold starts like overnight.. I do this on my 5.4 and it eliminates the start up rattle. Hopefully it's also prolonging the life of the engine.
Had my 2019 Limited repaired under warranty in 2020 for the same problem. When it happened again in 2021, I traded it in. I have zero faith in that motor.My wife's 2019 has started making a noise on cold starts. I will attach the video I made this morning. Please advise if you know what might cause this. It is close to 50K miles.
2018 Expedition sound on cold start
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.youtube.com
