5280tunage
So I was literally just getting ready to change out my spark plugs and coils, when I went to pull the engine cover off and found this mess. It only appears to be on the drivers side, the passenger side looks completely fine. Any thoughts? Is this likely a bad intake manifold gasket? It's pooling in the bolt hole just below the two gray hoses, above the filler neck so it's not like it's just leakage from pouring in fresh oil. The entire drivers side valve cover looks covered in the dirty goopy oil layer. If anything, i'm wondering if this is a left over issue from the phaser replacement I had a couple years ago.
Appreciate some thoughts, it is under warranty but now I'm thinking I shouldn't do the plugs and coils till after I have it looked at so they can't blame me for something.
Thanks in advance.
Thanks in advance.
