Battery issue
TJ Toronto
Toronto
Hello
I recently had an issue with the battery draining after being parked for anything more than 1 day. I brought it to the mechanic, who said they checked everything and it was just the battery. So it was replaced about 3 weeks ago. It has been parked for the last 7 days and today when I went to go out, it was dead again. Not even doing the ticking noise as it often does when a battery needs a boost.
I boosted it and it started. I drove it back to the mechanic, who seemed shocked to see me, and explained why I was there. I decided to turn it off at the shop so he could see. Again, I had to boost it when I left. He says he’s going to check the alternator. Also! I should mention, this time as well, as soon as I boost it, the passenger side headlight burns out. This has happened about 3 or 4 times now. The bulb that burnt out today is about 4 weeks old. I’m beginning to get really frustrated and am considering burning the truck to the ground.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Sounds like a phantom ground and/or a short somewhere....
After getting a known good battery, start at the battery cables & clamps, which could be causing either or both of these issues, then work your way down the line to the various places that could have the above...
The headlight burning out after boosting could be from a power surge too, but that would warrant an alternator & voltage regulator test, as well as the headlight switch itself...
Just some suggestions to think about, I'm not an expert at this, I am merely passing along my general knowledge of & experience with how cars work :D
Hello
I had the right low beam headlamp built burn out several times, several weeks apart. I was buying high-quality bulbs.
The last time I changed it, I noticed the lamp socket was slightly burned. I tried to clean it, then used silicone dielectric grease on the bulb contacts and the lamp socket.
I bought the vehicle new and it has never been damaged or wrecked. The lamp assemblies are the original. 2015 Expedition Limited 4x4.
So far, the cleaning and dielectric grease has prevented the last new bulb form burning out.
You may want to remove the bulb socket and look at it closely with a flashlight, or in bright sunlight.
TXResponder
Turn on your headlights and check if your headlights flicker a little bit when cranking to start the truck. If so, that's one of the signs it's the alternator.
Also check that your battery voltage is ~13.9-14.1 with the truck on (and all the electronics off) after a short highway drive. If it's not, it's probably the alternator again.
It sounds like it's not charging the battery while you're driving, leading to the battery getting depleted.
DAHE
GA, USA
with the car off and doors closed for at least 30 minutes remove the positive lead from the battery. put a multi-meter between the positive post and the lead, start with the 10 amp scale as a precaution. There are some capacitors that may take a few seconds to charge but the reading should stabilize below 0.1 amps. If the draw is less than 0.1 amps go to the lower reading scale for a more accurate reading. If you are above 0.1 amps you need to figure out which circuit is causing the drain. I usually start by pulling fuses for the each of the light circuits.
T
TJ Toronto
Toronto
Thank you everyone for your insight and info.
Unfortunately the vehicle is still dead. It has spent a total of 3 weeks during 3 visits at the mechanic. After each visit, I was told it was fixed and then it turns out the next day or two, it was dead again. I’ve already put over a thousand bucks into this issue. So needless to say, the mechanic is useless and I am beyond frustrated. I think it’s time to put this truck out to pasture. It could make for a pretty cool bon fire. It’s truly unfortunate as it is in such great shape otherwise.
KRGS
Lancaster SC
Take the battery to a local auto parts store and get it charged overnight
Then do a parasitic drain test. Requires the battery to be installed for about an hour before doing. I performed my test with a $6 Harbor Freight multimeter
My drain was Fuse 37 in the engine compartment. Still haven’t figured out the actual problem but I pull the fuse when the truck is sitting
