2006 5.4 Struggling to turn on sometimes.
BlackoutExpy
Arlington
So sometimes I turn over the truck and it cranks but wont turn on. Sometimes you hear a grinding noise. Dont know if its me or not but I feel like it happens more when hot outside. Most times it turns on no issue. But just recently it would crank turn on but like weak and then turned off. I do hear like a grinding noise sometimes. When this does happens it feels like it dies but will turn on next try.
kep5niner
Army
MO
In the grand scheme of things, starters are cheap and relatively easy to swap out. That would be my first step.
whtbronco
Winchester, VA
If you remove the starter and the bendix is grinding on the flywheel you'll see the teeth worn down some. I'd probably go ahead and have a spare starter on-hand just in case.
