Coolant Hose Leak
dwinchell92
illinois
Help!! I have a 2018 ford expedition limited 3.5l eco boost v6 twin turbo. I started having a slow coolant leak and not were loosing a lot each day. I chopped it up being a leak in the hose, but has anybody had anything similar happen? This is my main daily driver so I need to get this fixed quickly. The weird thing is the coolant level will not drop below this mark. If you can see in the photo, there is a crack on that piece that connects to the reservoir, but I cannot find this hose anywhere online to replace it myself instead of hiring somebody.
dwinchell92
dwinchell92
illinois
It’s only overheated 1 time when this first starter otherwise it doesn’t overheat
I had at least four separate coolant leaks on my 2015 Expedition Limited, purchased ne:
Coolant hose quick connect.
Water pump.
Degas bottle (coolant reservoir).
Turbo cooling line.
The coolant reservoir would leak when the fitting with the metal insert was wiggled - intermittent leak. The dealer replaced the coolant reservoir, which eliminated the leak. The leak was not from the hose connected to it.
bobward757
My 19 expedition was leaking from the plastic fittings that go into the radiator. It’s a three-piece hose. It’s all one assembly about 200 bucks for the hose and where it connects to the radiator is a plastic fitting and that’s where mine was leaking exact same symptoms as yours.
dwinchell92
dwinchell92
illinois
I’ve looked online and I don’t know what I’m looking for. Or what’s the name of the hoses
Password
Dealer wanted $1200 to replace the heater core hose....this might be the same issue. Got Ford corp to drop the cost to around $500, still robbery though.
bb37
Member Relations Specialist
Indiana
Watch a few videos of guys replacing the heater hose Y sections on Expeditions and you may have a better understanding of why the labor charge to do so is so high.
GixxerJasen
DFW TX
I wish I didn't relate to this thread. Mine is in the shop right now getting new hoses installed and it's not cheap. I'm thankful that when it puked and blew the over temp warning 2 blocks from my house rather than leaving me and my family in the middle of nowhere at night.
bb37
Indiana
Are these coolant hose failures due to the plastic Y pipe failing? Or, due to the aluminum crimp sleeves that are used to clamp the rubber hose to the Y pipe splitting and releasing its clamp?
GixxerJasen
DFW TX
Based on my research, the answer to your question is "Yes." Failures have occurred in both places. I was apparently lucky (unlucky) enough to be one of the ones to have the failure back by the rear heater core.
HILLY
Greenville, SC
When I had to replace mine the crimps were starting go at the firewall fittings, but ultimately my leak was the plastic fitting by the radiator hose.
GixxerJasen
DFW TX
Can we just replace those crimp sleeves with traditional hose clamps or oetiker clamps?
bb37
Indiana
I've seen guys on YouTube talk about putting worm drive clamps over the aluminum sleeves and cranking them down until the split in the sleeve closes.
GixxerJasen
DFW TX
I'm paying stupid money to get them replaced, simply because we have two family road trips before the end of the year and I need this truck reliable. But it does beg the question of what preventative maintenance can we do so I'm not paying this again in another 50K miles. That's of course if I still have it in 50K miles, seems like it's always something. When it's running it's great, but when it's not...
I'm rather surprised I can't seem to find aftermarket hoses out there on the market. Seems like there'd be some money to be made since the Ford ones are junk. At least Doorman has metal Y pipes to replace the crappy Ford plastic ones, but not sure how good those even are.
dwinchell92
dwinchell92
illinois
I got quoted today $1000 to change both hoses. Does that seem right? That seems high to me. The hoses are only $300.
GixxerJasen
DFW TX
Go back and reread this comment in this very thread.
Looks like 5.10 labor hours for the replacement if it's the same as mine was. Multiply that times your shops labor cost.
Password
How did you get them to drop the price?
My memory is terrible but I know I complained of the cost, I believe the dealer setup a correspondence number and then I called Ford customer service to complain about the cost. Ford corporate authorized the cost reduction.
