BoolFighta
Hey I’m looking for the factory radio wire diagram can’t find it anywhere
Putting in after market radio(hard wire)
Where did you get the switched power source fromI will say most of these have a red wire that is not switched power. When I installed my aftermarket radio I had to find 12V switched power under the dash.
I used a test light under the dash, found a +12 V switched power that wasn't being used. I believe they do make a CANBUS adapter as well but finding a red switched power was not an issue once I figured out the red in the harness wasn't used.Where did you get the switched power source from
Can you please give a little more specifics on where you found the unused switched power wire?I used a test light under the dash, found a +12 V switched power that wasn't being used. I believe they do make a CANBUS adapter as well but finding a red switched power was not an issue once I figured out the red in the harness wasn't used.
Just curious, why do people not spend the extra $25-30 bucks for a plug in harness?
It's been a couple of years, but I found a couple of unused connectors under the dash right under the steering wheel. I used a volt meter to find which one was +12V when the key was on and wired that into the red on the new radio harness.Can you please give a little more specifics on where you found the unused switched power wire?
