Clunking From Transmission Area/Rear End Over Rough Roads
apex96
I’ve been dealing with a clunking noise over broken pavement. I’ve had it looked at by more than one shop. Every shop so far has pointed to the front end.
Clunk started shortly after having the trans dropped to replace a torque converter. Took it back to the shop and they supposedly tightened up some form of heat shield. One of the rattles clunks I was experiencing after the trans drop did cease however there was still a small clunk.
Replaced all sway bar end links and bushings l, clunk still persists.
Over the past year I’ve replaced most of the front suspension because I wanted to lift it a bit over stock.
Replaced Bilstien 5100s with Icon front coil over setup, clunk still persists. Still have 5100s on the rear.
Had a mechanically inclined family member ride with me and they feel it’s coming from the back area or transmission area but not the front. I feel their assessment is correct as I’ve gone over the entire front end and can find no worn parts that I haven’t already replaced.
So now… After having a trans dropped three different times, could the clunk be related to bad trans mounts? It’s gotten absurd that everyone can hear it and say it’s the front but then also say everything in the front end is tight…
I’m done throwing parts at it. Again clunk is primarily over rough roads but it’s also present when climbing grades on the highway and the trans is under load and down shifts. Also present but very faintly over rough highway stretches too. The most noticeable clunking almost rattle noise is slower speeds over rough country roads…
Any helpful thoughts appreciated at this point.
Fastcar
Army
FL
Yup, rear shocks, frozen shock or any of the rear suspension rubbers. Or it could be a cracked engine or trans mount. You have to check them all.
BillyTheKid70
Transmission Mounts…
Remember sound travels, so it could be rear sway bar or shock mounts.
I just replaced driveshaft recently. Still have intermittent clunk. I had tranny replaced in August with no issues so far. We inspected last night as clunk is more frequent. And long behold a snapped tranny mount bolt. I'm hoping replaced tranny mount bolt will resolve this issue. Thoughts. Thanks BTK70
BMW2FORD
CT
If you can rent or buy this kit it would help.
It simple to use and just clip the probes to various areas then drive and listen to narrow down the location.
