2011 Ford Expedition XLT 5.4 3v - Idle issues about 60% of the time - No codes - Engine runs great otherwise
ejs_flys
Northern Virginia, USA
I have a 2011 Ford Expedition 5.4 3v with 260k miles. Owned since new.
Issue is rough idle about 60% of the time. Rough in the seat of your pants. It never stalls but at times it appears to be close to a stall and other times it runs as smooth as it should.
No codes.
I'm 61 and work in high tech but spent the first 26 years of my life working in my fathers Auto Parts store and Machine Shop in North Central PA (best job I ever had). I do most of my own maintenance on my vehicles.
I purchased a Topdon Phoenix light 2 scanner that reviewed on Scanner Danner's channel.
I have replaced all the timing components with OEM as well as the Melling Hi Volume oil pump. This included chains, guides, tensioners , phasers, roller followers with the smaller oil holes, lash adjusters and both solenoids. Again all OEM.
I even replaced the throttle body with an aftermarket one because I broke some plastic on the original but it I was having idle issues with the original one as well.
I have replaced the Mass Airflow sensor as well but no change.
Oil is changed every 7k and now using 5W30 Mobile One instead of 5W20 Mobile One due to mileage.
I also use the Purolator Boss oil filters and change them every oil change.
I run Seafoam through the gas and oil on occasion to ensure the inside is clean.
When I had the valve covers off the top of the head was clean as if new. No sludge or discoloring.
I have replaced all the plugs, checked gap, torqued them to spec and replaced all the fuel injectors and COPs as well and all with OEM parts.
It runs great while driving. Acceleration is perfect and from zero to 60+ it runs better now than it did when new.
Gas mileage on a trip is over 19 MPG with 87 octane and over 20 with 93.
There is no knocking or any noticeable noise from inside the engine.
Short and long term fuel trims are low where they should be and normally hover around the low +- single digits.
I have spent a lot of money on this and have had one shop try to diagnose the issue twice but they came back with nothing significant.
The shop I used said they can sense a vibration at low RPM using one of their tools but to me that is hard to tell if there is a mechanical issue or a fuel or air or spark issue or even torque converter issue.
As far as I can tell the VCT error value hovers around 0 as well using the Topdon.
Relative compression is perfect.
Power balance is fairly good with no detectable misfires and the little bit of imbalance could be caused by one of the items noted above.
I watch Scanner Danner's channel and Ford Tech Makuloco. I followed his suggestions on the timing component refresh.
What I am looking for is if anyone knows of a good mechanic in the Northern Virginia area who is a good diagnostic technician who may even have experience with Ford 5.4 3v engines.
I have had many theories but so far none have panned out. I wonder if at low RPM the PCM is not giving enough power to the COPs at times to keep the idle smooth but not low enough to cause a code.
I am lost and have exceeded my diagnostic skills and I am not ready to throw the towel in yet.
Any ideas? I would appreciate.
Thanks!
FOREST VIRGINIA
In my experience => seen spark plug wires that look fine yet don't function well when old .
An easy check is to find a really dark place @ night etc. I've had great luck with Bosch !
E
ejs_flys
Thanks for the suggestion but this has Coil On Plugs so each cylinder has it's own coil connected to the top of the spark plug. There are no plug wires and thus no distributor or rotor.
Dennis_H
DFW, TX
Quick thought... Does it do it in park, or in drive with brake pushed. Just trying to see if maybe something with tranny?
E
ejs_flys
Thanks for the post. It does it in park and drive when at a stop. If I raise the RPM with my foot on the bake I don't feel it. If I accelerate hard, sometimes you feel it and others you don't. That is why I am so perplexed.
I have replaced the transmission with a rebuilt one through AAMCO (what a horror story) and I asked them to also replace the torque converter and they said they did but I can't believe them. I should have marked it. I recently added Lubegard from Dr. Tranny for torque converter shudder to the transmission fluid with no change. But it was also having the same rough idle before the transmission swap.
I had the oil pressure checked and it was good and strong especially with the new Melling Hi Volume Oil Pump. With the engine hot it was at 32 PSI at idle (592 PRM) and 62 PSI at 2k RPM. I had the shop test it since you have to remove the pressure sensor for the idiot light and connect a pressure gauge (Really dumb design here Ford). It's in an awkward place and not easy to get to laying under the truck on a creeper.
Lately the idle is getting a bit rougher at times than it was before and other times it runs like a well-oiled machine.
Can't hear or find any vacuum leaks using the ether method but tempted to try a smoke machine but since it is intermittent I'm not sure that would result in anything either.
mr_dave
MN
The intermittent-ness would point me to an electrical issue, bad contact somewhere, broken wire, bad ground, failing coil pack, etc.
I had an intermittent miss on a previous vehicle and it turned out to be a bad coil pack wire, as in the wire looked OK but the copper inside was actually broken.
Can you see if only one (or a couple) cylinders are affected using the power balance scan when this occurs? That would at least narrow it down.
RBalboa
Brownsville, Texas
My 2 cents, my 2014 Expedition started doing the same thing, it wouldn't do it so much when cold, once I drove it in heavy traffic, once engine got pretty warm it would miss on idle, drive/parked. I finally found a mechanic that found the problem. Seems that that when I had a long block changed because the failed timing chain. This mechanic traced the problem with a large wire loom that runs from the ECU to the transmission, the loom was laying atop of the muffler and heating the wires, that is why it ran good when I was driving but once it got hot it would miss. Hope this helps.
Ryan L
Houston
I was thinking the same thing. Engine harmonics are a funny thing and what you can feel at low RPMs seems to melt away with higher RPMs (plus road motion).
Exactly. My wife’s 2015 Cherokee had failing mounts at 75k miles, and it wasn’t until I had her record a video while I tested for engine movement that it became obvious. Never occurs to me until watching a Scotty Kilmer video on YT that mounts are often overlooked and neglected on aged vehicles. I spent weeks trying to diagnose issues with the transmission. Thankfully I wasted mostly my time and not money.
E
ejs_flys
Mine was doing something similiar. Turned out the fuel pump pressure was too high and I had to replace the fuel pump.
Hi,
What were the symptoms? My expedition runs great as long as I am moving even at slow speed but at idle you feel it in the seat of your pants. It does not start immediately but when coming to a stop within a minute or two you start to feel it begin to stumble. And the stumble increases over time at times. Some times it runs fine but rarely it's stumble to a point where it almost stalls the engine. The idle RPM gets quite low too when it starts to stumble.
Do you know how it was discovered? Do they think it was pushing too much pressure and caused the injectors to leak?
Thanks,
Evan
E
ejs_flys
Thanks - I have checked them all and do use the power balance. They all appear to be even. I have swapped COPs and even replaced all the plugs again to ensure they were actual Motorcraft plus and not knockoffs. It does not appear to be to be a misfire type of event. Thanks for offering the advise.
E
ejs_flys
I have a 2011 EL Limited and this sounds familiar. Ended up being the heater hose at the "T" started to drip down into my #3 bank.
Thanks - No leaks. The hoses were replaced when I did the full timing job with new rollers and lash adjusters. I was having the issue even before I did the timing job and assumed that would have resolved the shudder. Engine runs great at higher RPM. Great gas mileage. Almost like new and acceleration is better than new at 260k. Go figure. Thanks for the suggestion.
FordMafia
Do you by chance have air in your cooling system?
I just did a timing job and made a post about this. When I filled my coolant back up it took less than what I drained out. While doing some google research I found a video on draining the air from the system and the guy said you can have rough idle when there is air. To be fair he was working on a '92 Honda prelude and idk if that'd apply to our vehicles. I don't have rough idle myself but would love to hear if this gives you any positive reults.
E
ejs_flys
Thanks for the suggestion. No air in the cooling system. I really don't know how you would in a Ford v8 as compared to a Honda especially with the return hose on the top of the intake along with the thermostat. If there was air in the system you would not get a good flow of coolant and would most likely overheat. And I can have a rough idle on cold start as well as the engine running normal temp.
