StibbyWonder
Hi everyone.
I would like to ask, where should I start checking this hissing noise near the brake pedals of my Ford Expedition 2003 model XLT. When I drove it or I am just idling for a few minutes my engine check light went on, also the hissing noise will stop if I stepped on the brake pedals. I’ll post the photo of the code P171 & P174 and what was in it.
See photos below for reference:
Based from the above photo it states that System too lean in B1 & B2.
On the photos above are the contents under the P171 code based from the first photo there is a “freeze frame” and here are the datas informing the P171.
I done my research that some guys explaining the hissing noise is coming from the brake booster in the engine bay, they saying I need to replace it. Also in theory I am thinking only that once this hissing noise will be gone these codes will be gone too due to there’s a vacuum leak in the brake booster. I am not sure and asking for your wisdom on how to resolve this issue.
Thank you guys!
Thank you guys!
