Radiator fans
texasmafia
texas
fans come on every time I turn heat on or air conditioner, they run continuously until I turn off ac and heat, can’t figure it out, 2016 expedition
Cooling fan 2 is the a/c fan (passenger side). I would check the connector and wiring to ensure it is not damaged or corroded.
GaryH
Army
I think it's normal for the electric fans to come on when the AC is turned on. Not sure why they would come on when the heater is used tho. Unless the heater also runs the compressor like when the defroster is used.
Utah Driver
Utah
My 16 the fans always come on at start up. Even is it's 20 degrees outside.
