Rear Taillight Trim Piece?
ertx
TX
I pulled the tail lights off and broke the brackets that hold the assembly in place. What is this piece called? I need to replace it on both sides.
Ignore my attempt to hold the lights in place with zip ties…
East-TN
Air Force
TN
It appears you are showing two different pieces/parts...hard to tell from the pics. Are you wanting to know about the part with the zip ties, or are you wanting to know about the trim piece that's suppose to be removed (popped off) to gain access to the nuts holding the tail light assembly?
You may want to post the year, make, model and trim line (as tail lamps can be different based upon the trim for the same year models).
