Linksvu
Hey all, I’m hoping for some education or insight on transmission temperatures and cooling. I have a 2017 EL with the towing package that is used a lot, mostly mountain driving but then towing a few times a year. Over the last five years I have seen a change in the average temperature readings for the transmission and I’m wondering if there is a reason or something that can be done about it. Ultimately, I would like to keep this transmission healthy into the upper 200s.
I regularly watch the oil pressure, oil temp, trans temp screen. When we first got the expedition six years ago, it had 90K on it. For those first few years, the transmission temperatures almost always stayed within the upper 190s, say 196–198. Clearly there were sometimes it rose, but I do not believe I ever saw higher than 206.
Then about three years ago, when I had the fluid and filter changed, it started to consistently run in the low 200s, 202–206. Now, after doing another filter and fluid change, it is consistently running 206–210, and I’ve even seen 212.
So, two questions: how does the transmission cooling system work? Any thoughts or ideas of why my average temperatures might be climbing?
On the first one, I’m wondering if any inefficiency in my engine cooling may be contributing. Could it be things like the water pump or the radiator affecting the temperatures of the trans cooler?
On the second one, I’m wondering if choices in fluids, filters, or changes versus flushes might be making a difference.
Thank you for your help!
