KOMaynard
I have a 2018 Expedition (85k miles) that has been showing a P0521 code, however, 99% of the time the gauge on the dash reads normal.
I replaced the oil pressure sensor and did an oil change, however, the error code returned a day or two later and has continued to intermittently show. Once in a while the dash will read “low oil pressure”, however, the gauge will return to normal with a moment and/or upon restart.
Per Ford Pass this is the error “The engine control system has detected an electrical signal from the engine oil pressure sensor that is outside of its normal operating range.”
I took everything back apart and cleaned both the sensors harness plug and the wire harness plug with CRC Electronics cleaner, and the issue has remained.
I also want to note I found a little bit of oil in the intake tubes that I had to remove to access the oil pressure switch. Nothing major, and I’m guessing it’s probably normal, but I will note it.
Since this issue has started, I also began receiving Ford Pass warnings indicating “An Electrical Short Turbocharger Wastegate Actuator Motor or Associated Circuit Wiring” and “low boost pressure with the turbocharger”. Which I will note, I have experienced no signs of engine or turbo issues. The only time the vehicle feels underpowered is when it clearly gets put in limp mode after an oil pressure warning.
I also received these warnings: “Your Service Engine Soon alert is on because there is an electrical issue with your vehicle. Your vehicle may be drivable, however Anti-lock brake operation and other important driver assistance features may not operate properly.” and “Your service engine soon (malfunction) alert is on because there is an electrical issue with your vehicle. This may cause additional warning alerts and other features in the vehicle to not work properly. Your vehicle is drivable but not all driver assist features are active.” and “Illuminates when the system has detected a powertrain or a four-wheel drive fault.”
Has anyone dealt with these or similar issues? I don’t believe I’m actually losing oil pressure, I believe it’s wiring or some other error, nor have I experienced any drive-ability issues.
I also have an active recall for the 24E13 campaign. Which I don’t believe is related - but perhaps if there’s a needed PCM reflash/reprogram?
