Strange Electrical Problems
vapor
I have a 2000 expedition, about 3 months ago the radio and wipers would stop working while I was driving and would start working again if the car was restarted or sometimes if the bright lights were turned on. Just as I was ready to take it in for service these things stopped. Yesterday the radio stopped playing and would start again if the car was put in neutral and then in drive again. The next morning the wipers, parking lights and radio were on when I got to the car. Without the key in the ignition all electrical works just like the key is in the on position. When the key is in the ignition and turned to the on position the car starts on its own. While it is running every few seconds the starter will engage and grind. I had a locksmith check the key cylinder,starter switch and column everything there is ok.
Would like to know if anyone has had these problems or has some ideas
vapor
ghindy2002
indiana
mine did the same exact thing. Reseal the windshield and it will take care of the problem. It took me forever to get the problem solved.. But it is caused fromt the windshield leaking and dripping down on the GEM module
V
vapor
Thanks, I took out the fuse box and it did have signs of corrosion and water. I'm going to replace the box and see what happens.
ghindy2002
indiana
let me know how much (if you don't mind). When I took mine to the garage and they replace the GEM module it cost over 550.00. I think if I would have let it dry out I could have save the 550.00 and just got away with resealing the windshield.
Georgia
I have a 2000 EB that had some strange electrical problems. The radio would change stations all by itself continuously for 2 days. Then it stopped. Hasnt happened since.
Any advice on what to do to prevent this from happening again? Do you think it's a symptom of a bigger electrical problem waiting to occur?
Thanks
ghindy2002
indiana
Not sure on that one. Mine was GEM module that got wet from a leaky windshield. Until it dried out the powerwindows and radio would only work in park or neutral. On the dash my 4x4 and "add wiper fluid" would flash in drive, & running board lights would stay on with no key in ignition. My gauges would sweep intermittently. The heater would blow air also. All this would go on until the battery went dead. Sorry I c ouldn't help.
But I was glad to hear I wasn't the only one with a STRANGE electical problem. But also sorry we had to have the electrical problem,
V
vapor
my problems started several months ago with wiper and radio problems like yours, then they cleared up for several months. Just the other day the bottom dropped out with all the problems. You may want to take the time to either seal your windshield or take out the fuse box and look for water damage.
Several people have told me that the GEM is probably ok and just the fuse box needs to be repaired or replaced. I tried to open the box to do a clean job but it looks like it could be a real hassle( lots of small pieces to deal with). a new one is about 128.00 Iwill be replacing it soon and will post results.
Georgia
I took my 2000 4.6 EB in this morning to get the head gasket replaced. I mentioned the strange radio activity over the two days. The service advisor says "no problem, we'll just replace the radio". Now, i'm not sure that the radio is the problem, it may be purely electrical. Maybe in the fuse box or something. Guess i'll take the new radio and look in the fuse box for moisture myself.
V
vapor
I replaced the fuse box and everything is working fine, I assume the leak is from the windshield and will reseal it.
nsilta
still leaking!!!
Ok, There's a lot of these leakers! I had all the wierd electrical problems, took it in and Ford replaced both fusebox and GEM for $700 (both were heavily corroded) and told me to reseal the windshield. Ok no problem. So the recommended glass shop says "we may break it taking it out', guess what, it broke. $300 to replace and the next time it rained I had another leak! It drips right down the drivers post and on to the boxes. I cannot see any other way for water to enter the post except the windshield. Does anyone know of any other way for water to enter the roof post?
ghindy2002
indiana
thats not a good sign. After I had mine resealed a year later it leaked again also. Not sure where it was coming from. I bought a tube of aquarium glue and sealed under the rubber all the way down the drivers side on the windsheild. That seems to be working until I can figure what to do next. I have had about 5 really heavy stroms and I held my breath, but it seems to be ok for now. I will be waiting to hear how it drips down the driver's post.
Ronbo
Shouldn't this be a Ford Recall Repair??
My 2000 EB just experienced the same electrical problems that most of you have described. The Radio will cut out when the headlights are on and the car is shifted into Drive or Reverse. I also had the wipers go out and I fear that this is just the beginning of my electrical nightmare. Since it seems that this problem is affecting quite a few Expedition owners throughout many model yeras, should this not be a matter for Ford to take care of under a factory recall???
I am still waiting on the cruise control fix too. This is my 1st Ford since 1971 and I got to tell you that if these problems persist, this will be my very last Ford. I'm starting to regret my move from Chevrolet.
Ron
ghindy2002
indiana
It seems that the electrical problems are in the Expeditions I ahve a Ford truck and this has never happened. I read an article from Ford when the garage was reseaching my problem..it said that Lincoln Navigators are also having the same problem. There was a man who worked in my complex that had a Navigator so I thought I would pass the info on to him. He said he did have an electrical problem and showed me the inside of the Navigator, as soon as he opened the door I could smell the mildew and asked if he noticed that smell he said yes but he just thought it was from water getting on his shoes and being transfered to the interior. He took his vehicle in to The dealer and there was a problems with a leaky windshield and fuse box being wet. They did not want to do the work as warranty and he was very upset. I will still have a Ford truck over and other vehicle.
akbergmann
New Jersey
Me too!!
I have an EB Expy and it started having the blower fan staying on problem. I brought it to the dealership and they replaced the GEM module and re-sealed the windshield. Here it is a year later and the demon has just resurfaced. I haven't stuck my head up in the dash to look at the fuse box. Incidentially, this occurs after a heavy rain.
I think that Ford needs to have a recall or a sevice bulletin.
ghindy2002
indiana
I think your are right. But Ford does not even think it is their problem. Ford dealers just looked at me like... are you wanting us to repair it at your cost or not. I would like to know why the windshield keeps coming unsealed..??? I would think that if your air bag deployed that it would not protect you as well becuase if the windshield is not sealed properly it would blow out the windshield instead of the bag staying forward when it explodes.
Not sure how to prod Ford into making a recall on this but I think they should.
Ronbo
I just tried to seal the windshield by running a bead of silicone along the bottom edge of the windshield. We'll see if this works or not. I can't believe how rusty the area underneath the dash is. It is incredilbe that Ford has not acknowledged this problem nor taken the initiative to try to remedy it. Come on Ford, if your listening, do something about this problem before you cause some really unsatisfied customers. My 12 year old Chevy is not nearly as nice looking as my Ford, but it sure has none of the problems that I am seeing with the Ford. The cruise control works, it has no rust in or out, and it is bone dry inside. Am I asking too much from a $35,000 car???
ghindy2002
indiana
When you run that bead of silicone...run it down the post too. From the leak I have a mildew smell, any ideas on how to get rid of that odor anyone?
Ronbo
I will seal the posts next weekend, but fortunately, for now anyway, my Expedition has not developed a mildew smell. I guess I would suggest some Fabreze, or maybe you could shampoo the carpet AFTER you have tried to seal the windshield. Again, as I've suggested before, these are NOT things one should have to do with an $35,000+ vehicle. Hello FORD, are you listening????
ghindy2002
indiana
The mildew smell is coming from under the dash..I guess I could try to fabreze some how under the dash. The carpert never did get wet, that would have been too easy.. You are right we should not be worrying about Thsi stuff. But I guess a vehicle that smells like a basement does cost as much as a basement. Unreal.
akbergmann
New Jersey
Maybe?
I don't know about the rest of you but this only happens when there is a heavy snow or rain and the truck is parked. I can drive it through a carwash (high pressure spray) and I can drive it through the rain, even heavy without any of these problems.
Therefore, I look to see where water would run down a non-moving vehicle. If you look at the diverside windshield rubber seal, it has a channel that funnels water down to the top of the front fender. At the same area there is a stamped joining of the frame. I had an area that was not stamped together and maybe there was some water getting in that way. Not Sure but I sealed it with silicone. I guess, I'll see if it works
Wish me luck,
Karl
