2005 Expedition Police Undercover Unit
05PIExedition
Ontario Canada
Hello---new to the forum---new to the Expedition ownership
Just purchased a 2005 XLT expedition--former police undercover unit---but well equiped---4wd, HD tow pkg, massive run flat tires, leather interior, power seats, heated and a/c seats, 3rd row 60/40--and not too chopped up from removal of police equipment
Excellent shape and only 8,500 miles on it---clean carfax---got it for a steal on price ($17,300 USD) because of ex police unit---so worth some grief to bring it back up to civillian fit and finish after removal of police equipment
I have an issue with the 3rd row seating---appears they removed the power fold switches for the third row seating---I can buy the switches easy enough---but after pulling it apart I can not see any pigtails in behind the interior trim panels, or even cut harnesses that would have run power to them. Leads me to think they were never installed in the vehicle, but seems odd that they would put the power 3rd row in and not the electrical (at least the pigtails or wiring harness being present behind trim panels)
Is anyone else aware of if there is a special police model run by ford where they do not install the wiring harness, but do install the poer 60/40 leather 3rd row seating?
Has anyone else run into this issue? If so how did you remedy---looking for suggestions
Worst comes to worst out come the wrenches andI will remove the third row altogether---but wanted to see if there was a relatively straight forward solution before resorting to somplete removal
05PIExedition
Ontario Canada
They are definately power seats
They both have electrical motors on them and there is no way to manually have them fold down that I have been able to find
Without them being able to fold down the rear cargo space is limited to the 6" or so behind the third row seating
green03
College Station, TX
I would suspect that the switches were removed then..... The harness has to be in there behind the hole where the switches are somewhere....
Matt
05PIExedition
Ontario Canada
That was my thoughts too---however after literally ripping out the entire interior clear through from the tailgate to the passenger doors I have yet to find a connector, a pigtail, or even hidden cut wires amongst the harnesses that are there
Has me baffled and the only thing i could think of was perhaps ford did a special police production run where the harness was not included
05PIExedition
Ontario Canada
that is the wierd thing---the actual toggle buttons are there, 4 of them---but the functional switches are not, nor is the wiring behind them
2 buttons in the rear behind 3rd row on passenger side and 2 on driver side between the 2nd and 3rd row seating are present---I do not think it would be normal to put the buttons there but nothin in behind them---if it was a faceplate to cover holes for an option the vehicle not equipped with then it would make sense
JUST4FUN
Admin
Moderator Administrator
Il
They may have moved them to a differnt location
like the switch panel they had mounted for the lights
and seren
05PIExedition
Ontario Canada
Just4Fun
Ding---a bell just went off after reading your post------excellent point--- I will dig around in dash area and see if I can find wiring there
Many thanks
JUST4FUN
Admin
Il
I WORK ON POLICE CARS I KNOW HOW THEY THINK
IF THEY USED IT FOR SURVALLENCE THEY WOULD NOT WANT TO GET OUT OF THE CAR TO AJUST SEATS
05PIExedition
Ontario Canada
Bingo!!!!
That was the answer---wire harness was burried in behind the dash---I re-routed it back to where it shoud be and everything works great now like original facotry intent
I would never have thought of looking for a dozen eggs in the bedroom "so to speak"
Many thanks for your insight on this
Regards
Karl
