HID Lights
Expeditious
Motor City
Having bad luck finding HID's that last more than three months at a time. Does anyone have any suggestions, and if so how long have they lasted?
Thanks in advance!
Mike
Newport News, VA
ebay...$35...had them for a year until i got my headlights retro'd...putting them in my wifes car...also check out ddmtuning...lot of ppl on here have bout from them and they last...but my fogs come on everytime my headlights come on and no probs...but i got mine from ebay for $35 and was very happy
JTKustoms
Boston
mine are from ddm tuning, like 45$ with a lifetime warranty.....havent had a problem yet and have had them in for about a year
sgtowing
Supporting Members
Valrico, Fl
x2. Xentec's from Ebay
Thermo
technical advisor
I bought the $35 HIDs from E-bay and haven't had any issues for over 3 years. Granted, I don't use the lights all that much. I have done a friends Jag and he has had nothing but issues with one set of his lights. The other set we installed have worked almost flawlessly for a year.
The big thing to keep in mind is that HID bulbs/ballasts like as much voltage as you can give them. So, using a separate relay harness powered directly off of the battery is best. If you are powering them through the factory wiring, that is very possibly where you problem lies. The headlight switch is starting to go and it is dropping too much voltage to be good on the ballast which is leading to the ballast failing, therefore the problems you are seeing.
Also, look at the way that you grounded the ballast. If you don't have a good ballast, again, this is causing the ballast not to get the highest voltage it can get, leading to the ballast working harder and failing sooner.
walnuts4x4
Watertown, NY
i got mine on ebay from "hidgate" dont know if they are still on but over 2 years and no problems
joecrotch
santa fe NM
the ebay lights are ok I here they are getting more reliable but for me if your switching to HID's its because you want quality lighting. HID's are not made for reflector housings and you will never get the lumens that your halogen gave you. anyway rather than me typing for hours here is a thread everyone thinking of HID's should read.
http://www.hidplanet.com/forums/sho...tand-about-HID-kit-users.&highlight=ebay+kits
If your buying from ebay or companies like DDM tuning, Xentec, ect then if your having problems there is nothing to complain about, thats what happens when you buy a communist copy of a product.
Dexter
Houma, LA
DDM Tuning is the way to go. I got 2 sets from them and they last. You can also get a lifetime warrenty for very cheap.
