Poll about 5.4l V8 and mileage
5.4l V8 and mileage
  • You are under 100k and have had major issues.
    Votes: 44 8.3%
  • You are over 100k and have had no major issues.
    Votes: 223 42.0%
  • You are over 150k miles.
    Votes: 164 30.9%
  • You are over 200k miles.
    Votes: 88 16.6%
  • You are over 300k miles.
    Votes: 12 2.3%
  • Total voters
    531
Hampton, VA
04 EB with 152K...replaced alt...coil conversion cuz the bags failed...head gasket...coolant leak...fuel pump...that is all
ssbroly
Ohio
posting again
2000 EB, just rolled 196K, 5.4 working on rear upper trailing arms now, busted them loose with pb blaster, sprayed them 4 times, once per day and let soak overnight till parts arrived, 24"-1/2" drive breaker bar and a box end. And a lot of ibuprofen afterward. This thing has never been garaged and serious cancer underneath it. I'm gonna cry when I retire it....
mcppat
Connecticut
'06 EB / 132k - Only issue so far was a grinding starter (pinion not meshing with the ring gear). Just dropped in a new starter yesterday which seems to be working fine, but it's the 2nd one in 6 months so we'll see if it lasts......Also may be time for a tranny flush (shudders slightly at low RPM when lightly accelerating).
spsfrank98
US
03 EB 127,000 just coil and plugs replacement getting 14.4 mpg runs great
Sent from my XT1585 using Tapatalk
hammerg26
North Georgia
Just hit 160K. Not a lot of issues - just had transfer case motor replaced... other than that, normal maintenance...
brick
Atlanta
2003 EB. 200,000 miles, no issues
2016 Limited 4,700 miles, still new
tifanydire
