14+ Suspension on 2010 Expedition
floresedgar8955
Hi, I have a 2010 Expedition Limited. been doing quite a bit of research, I’m wanting to install Bilstein 5100’s on it but from what I understand it’s only offered in 2014+ models.
After extensive research, I understand that the 14+ REAR STRUTS will work on my 2010 as they are the same. Fronts wont due to the lower shock mounting point.
Yes I understand the F-150 struts work, (but it’s a different spring rate & it’s much taller.
Can I use a 14+ LOWER CONTROL ARM on my 2010 to utilize the 14 FRONT STRUTS ?
Upper control arms are the same.
Spindles are the same.
Lower control arms are clearly different due to the shock mounting hole.
I figured it’s the easiest way, I can just order 14+ struts and get the lower control arms 14+ and should bolt straight on and retain similar to factory height ride, but with a superior strut assembly over factory.
Let me know if anyone has any experiences or thoughts!!
mjp2
Howell, NJ
That's a really good question. As much as I've been under my truck replacing parts, including the LCAs, I never once considered upgrading them to the newer model to get more shock fitment options.
Definitely following this thread to see what comes of it.
JayB66
Air Force
Aurora, CO
Same Here. My 09 doesn't have any suspension mods yet, so, More good info is well appreciated.
Lynnii2
Navy
San Diego, CA
I appreciate the informations. I was thinking about do the same mod as well with buying the BILSTEIN 5100 and upgrading to the new lower control arm on the 2014 Ford Expedition. I will check out the parts from rockauto.com and get a total price.
Everything listed is limited lifetime warranty
The prices:
BILSTEIN #24336901 5100 Front $136.79x2=$273.58
BILSTEIN 24336918 5100 Rear $$128.79x2=$257.58
Total $531.16
DORMAN #526291 Complete Arm w/ Ball Joint Front Left Lower $116.79
DORMAN #526292 Complete Arm w/ Ball Joint Front Right Lower $116.79
Total $233.58
Rockauto discount code: 331733489290881681
Total $764.74
Shipping $108.95
Discount $38.24
Out the door price: $900.19
No members online now.
Landsbutter
