Mainer1
Alright, I've asked this question to fellow car owners, as well as my mechanic,
and for the most part I get the same answer, although other say differently.
Transmission specialist, please speak up on this one.
I had my transmission rebuilt on my 99 Expy at ~ 100,000 miles or so,
It was a mess, but it was repaired, and all has been well.
My question is such, it's been 4-5 years since I had it repaired. Periodically I'll check the fluid level, it was pink in color, as time went on, and as the years & miles have been tacked on, the fluid is burned, and no longer pink, which is normal.
I see this, and think, OK, time to do a change, maybe even a partial. So I go about asking this question, should I change it out? For the most part I get a big NO, don't touch it, leave it alone, I'll cause more harm than good in doing so.
I don't understand this, why shouldn't it be change, common sense says, yes, change it, it's old, others say don't, new fluid will damage the seals, etc.. etc.. etc..
What do you guys say? keep it as is (burned up)? won't this in itself cause the transmission to fail? I'm a bit confused, I want to do the right thing, in prolonging the transmission life, I certainly do not want to shorten it by doing the wrong thing.
Thanks
Thanks
