26 Expedition - no driver’s side audio
bhollis84
Petersburg, IL
2026 Ford Expedition Active with 202a package. Converted to covert law enforcement vehicle. After the upfitter got done adding lights, radios, etc. — the driver’s side front door speaker quit working. We assumed wiring harness / or some wire was damaged or came disconnected during the upfit. We’ve gone over everything with a fine tooth comb. Checked every wire we could find where the aftermarket equipment was added. I really don’t think it is a damaged wire at this point.
We disconnected all aftermarket equipment as well, no change.
The only thing we can’t rule it was when they were testing for ignition power if it caused some sort of voltage surge. But we have no way to determine that.
We are at a loss with that the problem could be. The source doesn’t matter — CarPlay, FM, AM, Bluetooth — nothing comes out of that driver’s side front door speaker. We’ve checked all wires, harnesses, fuses, etc.
Any Ford service techs in here? Anyone have any ideas?
Thanks!
iaazan
Phoenix
Could you try checking the wires in the door jamb? Maybe they got pinched?
5280tunage
colorado
not sure if it works the same on the 25-26's, but forscan let's you run the audio system tests as well, look for open circuits, etc. it helped me troubleshoot some issues.
