Silverstreak
Guys.. Forum Newbee here..
I have an extra 1999 Ford Expedition 4x4 that has been put to pasture because of a tiny oil leak behind the pass head. It drips on the cat and causes the dreaded white smoke only occasionally. Wife ejected it.
SOO.. being the low buck ride replaced out with a *ahem* new 4x4 Expedition.. I'm going to do some hacks on it to reduce the existing smoke because the engine/vehicle runs fine otherwise.
I want to delete all the cats.. so it can remove the main burning offender. Then possibly shield the pipe on that pass bottom side.. wrap it.. whatever it takes to reduce the heat, oil burning etc . I don't care if the truck leaks oil... as long as it doesn't puff the smoke. Get my idea?
So the gist is.. Remove the Cats. Replace with straight pipe.. and I need some MIL eliminators. Or do i? It already has a code up on the dash "service engine" ( probably O2 coated in oil already ) etc.. so will the o2 sensors actually cause problems with mileage, performance or will it just throw a code? If just a code.. I could care less.. hence the low buck mods here.
If It will cause issues in performance/mileage then I will just buy the MIL Eliminators and install them.
So douse me with your expanded Expedition knowledge gurus.
I'm ready to start hacking..
