omgjedis
Hello, I haven't really introduced myself as I am a pretty fresh owner of this 2000 Expedition, but I got it with and inherited miss and the owner (a pretty trusted coworker) told me he daily drove it before letting it sit for the last year or so. He said his OBDII told him it was the #6 misfiring. I am waiting on a new OBDII scanner, as mine keep getting stolen somehow, but should be here tomorrow. I got all new Motorcraft coils and plugs gapped the plugs to recommended .054, used dialectic grease on all the boots, but while pulling out the old plugs and coils, #6 had what looked like sandy grease. After swapping all the plugs and coils I am still getting a miss. Now there wasn't much I could do about cleaning inside the cylinder without pulling head and I am not at that point until i can do some diagnostics and research. What I have seen, if anyone has seen the same and can help out, is this could be a valve issue? Looks sort of like fine grit sand in grease on the coil and plug.
Should also mention besides new plugs and coils (oh yeh and replacing #6 it was the only non motorcraft coil and was also broken where the harness clips on) it seemed to misfire almost worse with the new plugs and coils. right after replacing let it warm up for a good 20 minutes (it's snowy and cold where I live) and then ran it around at around idle with little revs here and there for about a mile. The misfire seemed more of a typical lob you may feel from a high mileage V8 through this, with the occasional cough here and there. After it was nice and warm I ran it up and down a 3 mile stretch of straight backroad right by me and on the round trip 3 miles back really aired it out and at high rev it felt fine, 1000-2000 was coughing and rough and on coast it was fine. after this round trip i did an oil change and drove it around about half mile with no issue and then drove it about a mile at 25-45 mph with some deep coughs here and there.
Sorry to rant just want to inform best as possible. I used Mobil1 oil and filter for oil, new air filter, techron fuel system cleaner, and in the oil change used the lucas oil additive. The mileage is 254k but seems like it was well taken care of, My coworker got it a few years back and daily drove it until the issues started since he has many other projects. I will get a code check hopefully tomorrow and be better informed, but figured i would maybe get a head start if anyone is familiar with this issue. Thanks!
