01 Exp Rubber Vaccum Manifold Question
Diggerauditor
South Bend
I was replacing some degraded hoses on my 5.4 this weekend when I ran across this rubber vacuum manifold that attaches to the throttle body and branches off into 3 separate vacuum signals, it is cracked in half.
I can't seem to find a part number for a new one so I have it jury rigged right now. I know the red hose is for my fuel pressure reg but the other ones go to valves that look like bigger versions of the old TAD TAB valves on my Mustang. Any help finding a part number would be appreciated.
kidphc
Potomac, MD
It's a speciality vacuum connector for Fords.
We've replaced several on Taurus and Sables here at the shop. You are going to have a tough time finding it anywhere but the dealer, to be honest. A lot of times, we just build connectors using vacuum T's. Wish I could tell you what sizes we used but I don't recall off the top of my head.
I've spent sometime to try to find a part number, I'll keep looking.
kidphc
Potomac, MD
I can't find the part number. I can find the entire hose assembly on E-bay. Just can't find which assembly it is on fiche, so I can give it to my Ford Dealer parts clerk to get me a good part number.
Might be easier if you walk into a Ford Dealer and have them look for it.
D
Diggerauditor
South Bend
Well I went down to the local junkyard and found one similar, it had the big end and 1 hose fitting so I tee'd it. Worked fine. Also took care of the 0171 and 0174 codes it was popping. CEL is now off and no codes have popped for over a week, awesome!!!
