06 expo slow start
06expo
Tucson
I have an 06 expedition. It cranks for 10 seconds then starts and then runs fine. New fuel filter and fuel pump.
Any ideas?
46L281GT
KY
Same issue on a 2004. Have new filter but not new pump.
stamp11127
Temple, Georgia
Check fuel pressure with a good gauge prior to starting. I think minimum pressure is 28 psi, running should be around 35-40 psi. If it is below 28 psi then it is leaking down somewhere. Leak points can be the hose at the pump, fittings, lines and injector stuck open.
If the initial pressure reading is within spec then diagnose the electrical side of the fuel system.
