09 expedition electrical gremlin HELP
Simsy
pa
09 expedition EL xlt 193k miles
Since I bought this a few weeks ago I can’t figure the problem out.. when switching to 4x4 the dash and all electrical go crazy flashing , traction control light came on, abs , and brake light along with the wrench icon also went into limp mode (3rd gear only). I checked for codes while running and nothing came up other than a pending code of U0073 but I think that’s caused by the electrical surging. If I switch back to 2wd and turn the engine off and restart it will drive okay as long as I do not switch to 4x4
Please help thank you!!
S
Simsy
pa
Today I noticed the problem only occurs once I touch the gas pedal after switching to 4x4
Motorcity muscle
Motorcity
Have you tried disconnecting the battery and completely drain the capacitors. Hopefully someone with more knowledge with chime in. May have more info on f150 site for this issue.
S
Simsy
pa
i disconnected battery overnight and no change
Yupster Dog
Moderator
S
Simsy
pa
S
Simsy
pa
Did you ground out your positive lead to dump capacitor-stored power? Takes minutes - not seconds. Ground it out, go have lunch and then come back and try it! :D
Okay tried that. I also just noticed when turning off the heat in the expedition the heat turns off 2 seconds after switching it to off.. ya think it’s a wiring issue in behind the radio? This is a nightmare
