171 Code bank 1 too lean, 03 4.6 EB 2WD
FamilyFordforfour
California
I am loosing my mind on this vehicle I have changed a lot of parts: intake gaskets, MAF sensor, and the big one Injectors.
I have tested multiple ways from smoking it out, brake cleaner, propane, to soap and water with a pressurized system.
I have checked my o2 sensors, voltage is normal. I moved the injectors from one side to the other and I saw a slight change on my o2 sensors so I change the injectors. I checked all the lines before going crazy inside the engine bay. I checked the head unit for my vent system for the climate control.
The only thing I can think of now is something related to changing my timing cover. I know I had a code before changing the cover but can't remember if it was the lean code.
The only thing left is the ecu, and maybe somewhere behind the dash.
riphip
Memphis, TN.
Vacuum leaks in hoses, elbows or PCV. Find the problem first THEN replace known bad parts. Get a smoke tester to make it so much easier.
Hamfisted
Ft Lauderdale
