tedallen
I am in the process of replacing the original style bumper and lower valance on the subject vehicle with a different lower valance having slots for tow hooks (from what I can tell this valance and tow hooks were only available on 4x4 vehicles).
To my dismay, I noticed that the frame tubes on my vehicle are not pre-drilled for the tow hooks to mount. In fact, the frame tubes are actually different from those of 4x4s. I went back to a salvage yard and noted the differences between the front end of the frame tubes on 2x4 and 4x4 vehicles for the first generation vehicles:
My concerns are whether or not I would cause integrity issues with the frame rails if I were to go ahead and drill the 11/16" holes required to mount the tow hooks without the frame rails having the overlapping sections to drill through as well as the fact that the tow hooks might not be completely level because of the weld bead in the middle of the bottom of the frame rails where the tow hooks will be mounted.
It seems hard to believe that it could be cost effective to have two different front frame rail designs for 2x4 vs 4x4 vehicles but I guess there are probably more differences further back.
Has anyone else attempted this, and if so, have you experienced any issues?
Thanks,
Ted
- Bumper mounts are recessed 2.25" from end of frame on 2x4 and 3.25" on 4x4.
- Frame tube of 4x4 vehicles has an overlapping section within the bottom of the tube so that there are two thicknesses of the frame where the holes are drilled. The 2x4 frame tube has very little overlap where the weld joint is made in the bottom of the tube.
- The center of the front hole for the tow hook mounting on 4x4 is approximately 4 5/8" back from the end of the frame tube. This would equate to 3 5/8" from the end of the frame tube on a 2x4 to maintain the same relationship between the face of the bumper mount brackets and the tow hook mount locations.
Thanks,
Ted
