Spaznaut
30 psi isn't where you need to be on your fuel pressure. Think isn't closer to 40-50psi. Either your pump is weak or your repair has a restriction in it. Also the pressure regulator may have issues but depending on if the pump has even been changed I'd look there first. I replaced the original in my '99 with 285k miles last year.
