So I've replaced the other 3 wheel's shocks with 'minimal' difficulty. However it appears that to remove the top bolt on the driver side rear shock that you need to also remove the bolt holding the gas tank strap so you can move the strap out of the way. Is this the case or am I missing something?
TIA
TIA
