HighSierra49er
Every couple of weeks my Exp. will not idle at a morning start up. Starts super quick, as usual, then the rpm just dies off until the engine quits. Only happens in the morning. The only way to keep it running is to keep the rpms up with the accelerator peddle. No high-idle at all. If I disconnect the battery, which I believe resets the computer, then reconnect, the engine will again immediately start up and the fast idle and normal idle is reset and works great for another couple of weeks.
The engine runs super smooth otherwise. I bought my Exp. new in 2000, and with 264,000 miles on the truck, have only had to replace the fuel pump and alternator. Has yet to burn any oil, but I do a pretty good job at following prescribed maintenance. Best vehicle I have ever owned.
Thanks for any input you can provide.
Thanks very much for the valuable and accurate information that allowed me to resolve this problem the first time around.. Can't believe it was done with the only out of pocket expense of a new gasket for the IAC valve.
