2002 EB VHS to DVD Player
millerdbm444
GA
I have a question in regards to being able to use the existing plug at the VHS Player to tap into the Video and Audio + and - wiring (6 wires total and a shield drain) to make 3 RCA Jacks and plug in a portable DVD Player and use the existing Video Screen and factory wiring without cutting into the harness and splicing?
1. Does anyone know if they make a female plug (16 pin) with male pins that will connect to that harness and if so where I could get one?
2. Does this sound doable and would the audio play / integrate over the MACH Radio System?
3. I read where there are 3 AUX / RCA Jacks hidden behind a small panel in the Video Screen. I looked, but did not see any panel that looked like what was described in a post that I read and did not want to break anything.
Any help would be appreciated. Thanks in advance.
M
millerdbm444
GA
Problem solved! I found the 3 RCA Jacks already installed on the Video Monitor. They are behind what looks like an Infrared lens on the fwd. side of the monitor. It is a rectangular lens that pulls down with a bit of effort approx. 3/4" wide and 3" long... I plugged my daughters play station in with a DVD in it and it plays great and the sound is good too over the speakers as well. We had the AV switch in the Video Monitor selected to AV2 and the radio tuned to 89.1. I am not sure what AV1 frequency is, but I think it is either 88.7 or 88.9... Hope this helps. There are wires dangling from the ceiling, however we only use it on trips. I can live with it for now. If anyone does know about getting the 16 pin connector and making it more permanent that would be appreciated.
