2002 eb won't start
warschool
ohio
Battery went dead from sitting in the garage charged the battery and truck will not start just cranks.
AWD EXPY
Piqua, oHIo
Earlier this month I had to replace my fuel pump. Then it started fine. You should test for fuel pressure.
1997SCEBFEX
Northwest Panhandle
can you hear the fuel pump energize?
how old is your gas, do you treat it if it sits for a while, or are you running non-ethanol brand? When was the last time you changed your fuel filter?
all other items good to check as mentioned above.
PanHandler.
warschool
warschool
ohio
disconnected the battery and charged it overnight and it started the next morning. thanks
