synapse888
New to me 2003 Expy drivers power seat generally doesnt work. Switch wouldn't work in any direction when I got the car yesterday. Owner said it might be a fuse. Old 30 amp F.1.109 fuse tested good, but replaced anyway (fuse diagram) . Then the switch/motor does work and I set seat in the proper place. Next time I got in the car the motor didn't work again, AND the seat seemed to have moved forward to like maybe it's default spot? Then I put a 40amp in because thats all i had and it worked for a bit again, and not does not. The fuses aren't blowing...the motor just stops working.
ALSO whenever the drivers seat stops working the ability to use adjust the rear view mirrors also stops working. Same circuit.
Lastly is there some way to manually adjust the seat position. Basically I just need to be able to get it set in the right position for me, then it doesn't matter if adjustment doesn't work...as long as the thing stays where I put it.
Thank you for any ideas!
