2003 expedition Eddie Bauer
toms89
technical advisor
MD
After seeing the fuses you marked. I did notice my rear defrost one of the attachments to the window broke of the glass. Would that cause it?
Your rear defroster will not work then but is is not likely a load on the system.
Something is drawing significant load after you shut down which is draining the battery. You need to locate this "mystery" load.
B
bedrck46
The rear defrost is a heavy amp draw item. But being the wire came off that wouldn't mean it is the cause unless its grounded and if that was the case it most likely would have blown the fuse. The best way to find out what is causing the battery drain is to hook up a meter and see what the amp draw is If its high then removing the fuses that normally have power going to them should result in a lower amp draw then start to reinsert them one at a time to see which circuit/circuits are causing the problem When you first hook up a meter have in on a higher DC amp setting to see what the draw is and then lower the setting to a range that doesn't peg the meter
B
brown3
Minnesota
K I'm at the auto parts store now. Don't have a meter do going to buy one. I'll also buy a battery charger so I know I can charge the battery and won't be stranded
toms89
technical advisor
MD
A temporary fix till you find the offending circuit would be to disconnect the battery whenever you park for a given amount of time and reconnect before leaving. (Only one terminal necessary) This is inconvenient of course but not to difficult to do. It will keep your battery from dying due to any load. I did this with mine when my gem/fuse block was draining my battery before I could repair.
B
bedrck46
read the directions with the meter Make sure you have it on the proper scale(DC AMPS) and work down to milliamps, and the wires connected correctly. If the meter reads in reverse (a - amperage) just reverse the leads start on the high scaale and go lower as needed so you get good readings. If any problems just stop and ask, will be glad to help. If and when you find the circuit/s that are drawing high amps post your results. Also checkb the owners manula to find out what the fuse controls.
B
brown3
Minnesota
K I just got the reader and I'm at my house. Figuring out how to use it quick. Then i will test it out and post readings
B
brown3
Minnesota
Not really sure how to set up the reader. Only one they had was the innova digital multi reader 3300. Have options to turn the knob to dcv, acv, dca, dc10a, and ohm. I don't know very much about electric so thanks for helping me through this
B
bedrck46
start with meter being on DC10A as long as you not drawing more than 10 amps you will be ok
B
brown3
Minnesota
It sparked pretty good when I did that on that setting. That suppose to happen?
B
brown3
Minnesota
Am I suppose to disconnect anything or just touch it to the correct terminals with everything hooked up?
B
bedrck46
Only problem with that meter is you are limited as to the amount of amps it will read That is why I prefer using the clamp-on style meter but I realize there is a big difference in price
B
bedrck46
You will need to disconnect the NEG battery cable and then put one lead on the battery cable and the other lead on the neg terminal That what as known as being in series
B
bedrck46
do not put the meter across both battery terminals unless you have the meter on DC VOLTS
B
brown3
Minnesota
I ask about that this was the last one left at orielys. Not sure if I'm doing it right though it's sparks really good. I have it set at dc10a and the red terminal hooked on the left red one named dc10a and the black connected to the com. It sparked very bad and I thought it flashed 7. something. Had pulled it off fast
B
bedrck46
Start pulling the fuses that I marked up on the print Even 1.44 amps is to much of a draw with everything off Make sure doors are closed also pull the light on the hood and have the keys in your hand
