Robert
Hi all. I've read through a lot of the threads on here and I hope to get some help on my issue.
Problem: Rear A/C not working. Blows warm air.
Actions attempted: I followed some of the great advice on these forums and thought that my problem was the rear damper door motor (the damper door changes air flow from the ceiling vents to the floor vents and vice versa). That is working fine.
Then I checked the blend door actuator (thanks to ELVATO for the thread on how to take the quarter panel off). I took the actuator out, still connected, and changed the temperature setting (both front and rear)...the pin rotated. I also tried this with a new actuator and got same result. In addition I opened the actuator and all the gears were in good condition. (over kill but I'm desperate at this point to find the problem...)
Then I put a screw driver into the D shaped hole that the actuator goes into. I could turn it and feel the door inside opening and closing. The only difference I noted is that when twisted up...the air coming out of vents felt like heat. When I twisted the door down, it was cooler air. Not A/C'd air, but cooler than heat.
Any idea what I'm missing? Wondering if I need refrigerant. Not sure if this is the case because the front A/C works perfectly. Is it possible that the rear A/C needs refrigerant?
Any input / advice is greatly appreciated.
thanks,
thanks,
