korbinG
Wassup truck enthusiasts .
I'm now having a small evap leak diagnosed. Acquired at 270k miles, ran good, but during 2 years I replaced the spark plugs, one coil over plug, the heater diverter T by the 1st bank, the intake manifold after a coolant leak on the gasket, front brake pads, fuel cap, (the emissions testing passed my replacement fuel cap) front wheels u joint and drive shaft are removed after the u joint started wobbling on the highway, I replaced the front wheel vacuum assisted locking wheel hubs (they were grinding when a low vacuum happened at the top of the manifold), , and removed the 4x4 vacuum solenoid that activates the locking wheel hubs , (capped off the vacuum lines that go to it) I replaced vacuum hoses before the EGR, which allowed me to redirect the vacuum actuated HVAC blend doors, and I replaced a failed blend door actuator. My scan tool shows me (-1400 kPa) when start up idling for a few minutes leading me to believe the evap canister is clogged and not venting properly, but I'm here to get more insight about my cool truck and hopefully avoid big repairs or prolong the life of this 5.4L Triton engine. Suspension work is next, (I'm in hot arid climate) and I want to prepare to replace the timing chain and maybe top engine refining (valve lifters,) . Pretty soon. I appreciate advice and resources, and I'm concerned that the engine is burning proper ratios and keeping me from problems with the emissions people. Thanks in advance for some direction
