tedallen
I have a 1997 (gen 1) Expy that has over 343k miles on it and am looking to replace it. I looked at a 2005 Limited today that a guy with a dealer's license bought at an auction a couple of weeks ago. He says he replaced all of the plugs and coil packs and based on his description of the job and the fact I have done so many times, I believe he has done it.
The vehicle has 165k miles on it, is 4wd, heated/cooled front seats, does not have DVD/entertainment system, no 3rd row power. There is an on/off switch mounted behind a small panel in driver's side panel behind 3rd row seats which I suspect is for air suspension and I have read of issues with that and folks spending $1000 or more to replace components to eliminate it.
I looked it over thoroughly and found that it has the clicking and popping issue with rear AC/heat doors for diverting air from floor to overhead vents and blending for temperature. I also noticed that it has the 3 valve 5.4L which I think I have read is more problematic than the 2 valve versions.
I also found that the driver side mirror isn't collapsing all the way in or moving all the way out when pushing the toggle switch down. It is easily spun around for a fairly wide range by hand which does not occur with the passenger mirror. I'm wondering if a piece has broken in the swivel part of the mount and, if so, if this is something easily replaced? There are a couple of small rips in the leather seating (one in vented driver seated surface and one in leading edge of 3rd row seat), but other than that the interior is in very good condition.
I noticed some paint peeling on the rubber alignment bumpers that the leading edge of the hood rests on. I asked if he knew if the vehicle had been in any accidents. He said he didn't see any on the Carfax but didn't have it for me to see. i can get the VIN and order one myself. I don't think it would have come from the factory with paint on those. I worked in a Ford assembly plant for a number of years and don't recall this being in place at the time the body is painted.
I am scheduled to look at a 2003 with similar mileage that isn't 4wd but does have DVD/entertainment system in a couple of days. Both vehicles are the same price ($5000). I'm just trying to determine if I might be better off with the older vehicle with the 2v 5.4. I don't really need 4wd, but the HP increase in 2005 would be nice, although the boost in 2003 would still be more than my 1997.
My 1997 was using a quart of oil or more prior to reaching 100k miles and I know Ford claimed this was normal. However, over time this got worse. Now, at 343k, it goes through 5+ quarts in 3000 miles (using high mileage synblend oil). Is oil consumption any better on either the 2003 2v 5.4 or 2005 3v 5.4?
Are there are any other typical issues I should consider?
Any assistance is greatly appreciated.
Thanks,
Ted
Thanks,
Ted
