Hello All
06 5.4 runs drives does not go into overdrive?
Is there a solenoid on rear axle ? Or any other ideas?
Thanks I’m Advance
Mitch
BTW 105k on it
Theirs no solenoid on the rear axle. You'll need to run codes, if you get a p783 code, then it's possible a solenoid body or overdrive clutch has a leaky piston seal. The third possibility is your overdrive clutch is burnt up. Let us know what pops up.
