2007 Limited 4WD
tim preston
Florida
New to the forum. Air suspension was not working, and estimate to fix was outrageous, I switched to Arnott Conversion kit, and now I hear more rattles that when Air suspension was working. Any ideas on what I can do now, to make the conversion kit, be smoother over bumps? I only changes out the rear, did not touch front. Any help would be appreciated.
Also, need to change the lights on the front door mirrors, anyone ever had to do this and have any pointers?
Thanks.
gixer2000
Retrofit or Bust
Massachusetts
I would expect the conversion to be much stiffer so I would try to locate your rattles and check/replace the fasteners. I'm assuming the rattles are inside the truck?
ExpeditionAndy
Fort Wayne, Indiana
Thanks.
Do you have the mirrors with the amber lens under the mirror? If you do, there are two clips that you can release with a flat blade screw driver and the amber lens slides to the outboard side. You can see the clips with a flash light if you point the mirror up.
