2008 EL - Rear A/C Heater not Blowing
Matt Stockton
Dallas, TX
The rear a/c&heater is not blowing in my 2008 Expedition EL. Where is the blower motor? Where are any relays that I should be checking. Thanks in advance.
B
bedrck46
Blower motor is on the right side rear, There also is the Aux. relay box #2 in the same area.
Check fuse # 11 in the Battery Junction box and check fuse # 46 in the passenger compartment fuse box. Refer to your owners manual. Also when checking fuses always use a meter.
If the fuses check good then try turning the blower on and listen to the relays in the Aux Relay Box another item that could be bad is the Aux blower motor resistor assembly
