Salt Fever
Expedition has 95k miles took to dealer due to check engine light on. Dealer replaced plugs, fuel filter, mass air sensor, (tune up). Took home and noticed engine shutting off after shifting into gear from cold start. Also lost 4 - 5 (used to get 16 in city and 18-20 on highway) mpg city driving and highway driving after tune up. Took vehicle back to dealer who replaced the transmission computer (described to me)...same problem after repair with no improvement. Took back to dealer for 15 days where dealer replaced torque converter, several pids (sensor points) and finally removed computer software and reset computer. Said the computer was sensing 49% ethanol at startup then computer flooding engine with gas causing shutdown. Said the computer now senses 9.8% ethanol and engineer should run fine. Had back from shop three days and have engine shutting down on cold start when shifting into gear and horrible gas mileage. Have any of you experienced this or similar? Any suggestions for repair?
