2010 EL 3/2” lift + 35" + Tuner - pics
B
Bernard
NJ
Hi Bernard
Good job and very nice looking Expedition.
Regarding the Knuckle I find that the expedition part is the same F-150 RWD the part number is :
MEF117 (Front Right)
MEF119 (Front Left)
And the F-150 4WD part number is :
MEF116 (Front Right)
MEF118 (Front Left)
Thanks
Wow!! Great!!!
Thanks A Lot ----.
After you know what/how to look for, it all comes up right..
But it got me a bit confused.
It says that the same knuckles used for the 2009-on F-150 and the 2007-on EXPY are the F-150 Rear Wheel Drive. Not the 4WD version. But the EXPY is 4WD…
Ford_Forever
KSA
Yes I agree with you and I think that what make the Expedition (4WD) lower than the F-150 (4WD).
Also I found that the Shock Absorber in F-150 (4WD) longer than the Expedition (4WD) with around 1 inch.
You can see and compare the parts in that website:
RockAuto Parts Catalog[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=jo3ms94102b2rhhgk9mvqar1k6
Ford_Forever
KSA
Hi
I took a photo to compare the Expedition vs F150 both (4WD).
I find that the F-150 slightly higher than my Expy so I think the reason is tow thing :
1- F-150 has longer Knuckle.
2- F-150 has longer Shock Absorber.
but I dont knew about the ather parts.
B
Bernard
NJ
Hi
Where do take the parts measurements?
And what about the upper/lower arms, are those the same too (for the the F-150 and the EXPY)?
Looking at the pics you posted, by the looks of the shafts on both trucks, it does seams like the F-150 is a bit “lifted” than the EXPY..Other than that, from that angle, it looks the same construction.
I don’t get it.
If both the F-150 and the EXPY have the same parts with the same part number, how come the F-150 has longer knuckles?
As far as my understanding in IFS goes, the length/height of the knuckles do doesn’t determine the ride height.
Any way, I would like to know what are the differences between the 2WD and the 4WD knuckles, to determine if the F-150 lift kit knuckles will fit/work in the EXPY – but I can’t find clear pics of the two…
Everything is going so hard with those Expedition modifications…
capitlj
Thief River Falls MN
Spicer shows the same part number for the Upper Control Arm/Ball Joint on both the Expy 4WD and the F150 4WD. The lowers do appear to be different since Spicer/Raybestos does not list a number for the Expy 4WD and they do for the F150 4WD. I'd be willing to bet that the stock F150 4WD spindle would not only fit but might solve that high ball joint angle without going to a lifted aftermarket one.
B
Bernard
NJ
What year, for the F150? Which year have the same part number? Could you put a link?
I hope next week or the week after, I'll go to a local junk yard and try finding a used F-150 knuckle and upper A arm - see if it will fits..
capitlj
I looked up a 2008 Expedition 4WD and a 2008 F150 4WD
EDIT
Since it's kinda quiet here now I looked up all the way to 2012 and was still coming up with the same information. In 2012 tho the F150 did add some new part numbers based on options but I'd bet it's F150 Raptor vs all other F150's in my catalog.
Ford_Forever
KSA
good idea, if its work with you then it will be possible to install the F150 rancho quick lift suspension it will add 2".
and for the back i think enough to install the ford expedition rancho quick lift suspension it will add 0.75" + 1" spacer it will be ok.
what do you think guys ?
B
Bernard
NJ
Well, it sounds good but…
If it’s the lift you’re aiming for, why not going with the 3/2 or 2/1 or 2.5/1.5 or any other spacers out there – much cheaper and easy too…
capitlj
Because that ball joint angle is pretty extreme with the Expedition spindle. I would love to see if the F150's spindle/knuckle can be swapped in to alleviate that issue as it's pretty worrying to someone who's truck will spend some time off of the pavement. It would suck to be bouncing down a dirt road or through some snow drifts and have that ball joint fail. From the information we have dug up I think the 4WD F150 Spindle will fit on an Expedition. One thing I'm curious about is if the spindle swap alone will give any lift or if it will just correct the suspension angles once a spacer lift is installed.
B
Bernard
NJ
I totally agree.
The bal joint angle, in offroad, is just a accident waiting to happen - That is why I spend so much time to get the information regarding the F-150..
I don’t see how the F-150 alone will give any lift. I think it will only change the Lower-to- Upper arms angle – the lift is a factor of the Lower arm –to-chassis length…
In any case, I think that the Rancho kit doesn’t address the ball joint angle problem either – it does the same way of lifting as the spacer ones.
Any way.
The other (next) concern/thing to think about, is how/if the higher spindle (if it fits…) and the change in the upper arm angle change, will affect the vehicle beaver – as the Upper and Lower arms will NOT be parallel any more or less parallel then stock…
capitlj
True, but I dont think it could be any worse than than the angle on that upper arm with the spacer lift. That picture shows the suspension fully dropped out but that upper a arm can't be parallel with the suspension under load either. Someone would need to get the parts, install them and see if there are any issues. I think if anything the F150 Spindle would move that upper a-arm back into a more factory geometry. It doesn't look like there would be any clearnace issues with that ball joint being placed higher with the suspension under full compression either.
B
Bernard
NJ
OK. I think it is final…
The 2007-on Expedition and the latest generation F-150 have the exact Knuckles/spindles.
It is Ford part number 3K186 LH and 3K185 RH - it is the same for 2x4 and for the 4x4 versions.
There for, it is the same height and will not solve the Upper Arm/Ball Joint angle.
Another thing.
In addition to the taller knuckle’s “neck”, the lift kit’s Knuckles have a lower arm connection that is lower than the OEM knuckles (it meant to work with a lowering bracket for the lower arm), so it will give even worst arms angles…
I starting to think that the best available solution will be to modify an OEM knuckles…
B
Bernard
NJ
Not at all.
I'm starting to look for options on how to weld cast iron... this is, definitely, not a DIY project...
I know it can be done, because I saw it on the Rough Country F-150 lift kit installation manual...
An Expedition/F-150 knuckle is about $50-$70 (eBay) - have no idea how much is a welding for that kind of thing...
capitlj
Welding a cast piece is impossible acording to some shops, difficult according to others. I find it highly unlikely you'll find someone willing to give it a shot without some ironclad legal paperwork absolving them of any liability should it fail and wreck a vehicle worth at least $20,000.
B
Bernard
NJ
Too complicated..
The other option is to install an F-150 front lift kit (assuming it will fit) including lowering brackets for the lower arms and Knuckles but they go at list 4" and it is too high, for my opinion...
capitlj
I agree, an expy would need 4 inches in the back to make that work and unfortunately the F150 stuff will definitely not work there lol
B
Bernard
NJ
Even without the rear - with 3", I'm not so happy with the front half-shafts angle... I would prefer that the front axle would be lowered too...
Today I dissemble the front wheels and took a good look at the front suspension and steering, at varies positions - in full drop, the half-shaft outer joint boots are rubbing/leaning against the lower arm...
I just can't leave it the way it is now.
I think, eventually, I'll stay with the 3" I did and go for a lower arms lowering brackets + knuckles and leave the axle in its place...
Or
Concentrate on how to lift the rear to match a 4” front F150 lift.
I guess there is no way around it, if you want to do this right...
No members online now.
Landsbutter
