2011 POS 5.4-3 valve now getting all new rockers and cams
Goofy173
Ky
After getting new chains, guides, and phasers and that idiot mechanic not doing what I told him, that there's a tick under the passenger side valve cover and it's gonna be a bad rocker, now it's getting all new rockers and cams after another mechanic showed me the cam wear.
I knew I shouldn't just get the offending rocker replaced but after the former $1700 phaser job, I wanted cheap. But I considered pick and replacing bad rockers over however long would add up to lots of money, I'm just getting all 24 done for $2200.
My only consolation that the first mechanic ignored me that a rocker needed replaced, as there was a broken spring on 1 phaser, and at 225,000 it needed all that anyway. It did fix the really bad engine surges it was having.
Geez, I hope now at spending almost $4k since August, it lasts another 220k miles, well maybe an oil pump, but now that they have the higher flow pumps available, maybe that'll be the next failure and replacement.
G
Goofy173
Ky
$2500 including water pump and done. Got it back yesterday
scottc
british columbia
Hi Goofy173,
So glad I came across your post. I have a 2010 with 135,000 miles (220k km) and have a very slight tick starting on the passenger side. The VVT component R&R is done, so I got a quote for replacing roller followers from the Ford dealership.. The labour is 8.8 hours @ 144/hr.
I have asked FordTechMakuloko on two occasions if he could comment on repair hours for the job in his shop, but never received a response. Hoping you or any other forum member could put the 8.8 hour labour quote in perspective? thanks very much.
Did I read correctly that your 2200 quote included camshafts? Holy geez.
