2015 Expedition 3.5 EcoBoost – slow coolant leak at driver-side turbo, looking for input
H60John
Oklahoma
Hey all, wanted to lay out my situation and see if it lines up with what others have experienced.
Truck: 2015 Expedition Platinum, 3.5 EcoBoost, ~121k miles.
Background: Bought it ~7 weeks ago. Had a timing cover reseal / rear main / oil return pipe done right after purchase (warranty work). An oil drip showed up the day that job finished but has since resolved – no more oil.
Current issue: Now I've got a COOLANT leak (orange Motorcraft, bitter/watery) weeping at the driver-side turbo area. Symptoms:
- Only shows up after the truck is warm / driven, dries up overnight
- Drips a small contained spot on the driveway (~fist-size an hour after a drive), not a puddle or trail
- Coolant reservoir is holding steady
- NOT overheating, temp gauge normal
- Visible orange staining + a fresh droplet at the fitting near the turbo
Diagnosis so far: Dealer says left turbo internal seal, $1,833 to replace the turbo. Christian Brothers quoted $1,775 (Ford reman turbo, ~$700 labor) but that was off the dealer's diagnosis, not their own look. I have NOT confirmed whether it's actually the internal seal vs. the external coolant line/jiffy fitting/O-ring – from what I'm reading those clip-in fittings are the usual culprit and a much cheaper fix.
My plan (can't afford the repair right now, looking at ~a year out):
- Monitor reservoir level (check cold) + watch temp gauge
- Keep a jug of coolant in the truck, top off as needed
- Avoid long hauls / towing where I can (typical drive is ~90 min)
- Pay for a cooling-system pressure test ($80) to confirm seal vs. line before committing to any repair
- Possibly upgrade to AN/braided lines when I do fix it so I'm not chasing it again
Questions for those who've been here:
1. Does a slow weep like this realistically hold for months on careful monitoring, or did yours accelerate fast?
2. Anyone have it diagnosed as "internal seal / replace turbo" when it turned out to just be the external fitting/line?
3. For ~90-min highway drives, anything beyond "full before you leave + watch the gauge + carry coolant" you'd recommend?
Thanks in advance – trying to nurse it safely until I can afford to do it right.
17expi
Mt Shasta Ca
I agree with your "plan" except for the $80 coolant check, which won't tell you anything you don't already know, and braided lines won't do anything other than make your wallet lighter. It's probably one of those little O rings in one of those tubes that you can fix yourself. Pretty common leak and nothing to worry about.
99WhiteC5Coupe
I bought a new 2015 Expedition Limited 4x4. Never wrecked and passenger use only (no towing).
One of the turbo coolant lines began to leak coolant. I had the Ford Premium ESP, which covered the repair. (At the same time, the engine vacuum pump began to leak oil - also repaired). This was in the 70,000 - 80,000 mile range.
I recall the turbo coolant line was an involved repair, and the mechanic at Ford broke several exhaust manifold bolts during the repair. The ESP paid for the repair and the extra labor charge for repairing the broken bolts. The turbo had to be removed or loosened, but not replaced.
The line wasn’t leaking a lot, but I noticed small drips on the garage floor and also the engine coolant reservoir dropped about 1-2 inches in a week.
I don’t know if the coolant leak would accelerate quickly, as I took mine to the dealer and said fix it.
I’d be leery of making a 90-mile drive with the leak. Coolant leaks can worsen and where your engine is leaking is a difficult repair area. I am always cautious and do not risk a long drive with a known issue such as leaking coolant.
I wish you the best. Good luck.
Fastcar
Army
FL
Fastcar
Army
FL
Were it me I'd run it. As 17Expi says, it is probably one of those little O rings. Keep a jug of water with you just in case and keep an eye on it. No stop leak!! I'm surprised the dealer didn't want to sell you an engine.
H60John
H60John
Oklahoma
You are right, I mean we can already tell where it’s coming from. I appreciate it!
H60John
H60John
Oklahoma
100% surprised as well! I tried to call them and they said they have seen new cars go 1000 miles and need new engines so I should have bought a warranty if I wanted protection. I appreciate the input!
H60John
H60John
Oklahoma
I appreciate the input. I am very glad you had coverage!
I may shift priority here to repairing my wheel bearing on my Ford edge while I save up for the turbo line repair.
I was hoping to drive both of them until the wheels fall off. Good thing I didn’t say until the turbos have issues
(Trying to stay positive here)
H60John
H60John
Oklahoma
here is a better picture do you guys think internal or external?
17expi
Mt Shasta Ca
It's hard to say where it is coming from with a picture or even being there but it's just one of the cooling line O-ring seals and you could do it yourself., It shows you how on YouTube and the parts are cheap........not internal. Myself; I probably wouldn't fix it. Go on vacation over the mountains and don't worry about it. Just watch the coolant level once in a great while.
bityw
Central Arkansas
Disclaimer: YMMV.....literally.....
1. I have a 2015 XLT EL with this same issue on the passenger side turbo. It started leaking around 90k miles and has remained steady since then. It leaks more in the winter than it does in the summer. It only leaks when parked and cooled down, not warmed up or while in operation. I never got around to fixing it, and I'm at 205k miles now. I have maybe been through about 6/7 jugs of coolant in the past 5 years. I buy the cheap Supertech stuff from Walmart with the Dexcool logo. The cost of those 7 jugs over the years and miles hasn't been cost prohibitive.
3. I routinely use this vehicle in the summer to tow a boat sometimes ~90 miles one way to the lake and have only ever monitored the level and added as needed when cold before the weekend starts. I have also driven it all day over ~900 miles (AR to CO) having only topped it off the night before during my pre-trip walkaround.
TL;DR: Your first two points in your plan sound fine. That's all I've been doing on mine for awhile now.
BlackBetty
Army
Surprise, AZ
Judging from your pic it does look like it’s coming from the oil cooler line at the top. I’ve done this job before, and it’s not that bad.
Get new O-ring, bolts, and gaskets from dealer. A few days before actual repair start spraying all the fasteners. This can help get through some of the corrosion/ dirt for easier removal. I suggest finding Kroil penetrating oil. I’ve used many of the shelf brands, but it wasn’t until one of the guys at work gave me a can of Kroil that I felt I used something awesome!!! Used this to break fasteners loose on Apache helicopters.
Never seen it in the auto parts store. Only available on-line as far as I can tell. Anyway… tried to remove an exhaust downpipes fastener with no avail. Sprayed it Kroil, moved to the turbo oil/ cooler lines. By the time I got done with those the downpipe fasteners came right off.
Works well if you have a lift available. Easier on the back and/ or shoulders. The vehicle can be raised/ lowered to better accommodate you.
That leak can possibly get worse. I’d recommend changing it, but if money, tools, parts, or skill play a part it’s understandable. Also, keep in mind you know what’s going on so it’s not a problem to keep an eye on the coolant level. If you have a wife, girlfriend, or anyone that drives the vehicle they might not know to check; or how. That could be detrimental!!!
Should you decide/ when you’re ready to do it reach out; I’ve got all the torque values for all the fasteners.
17expi
Mt Shasta Ca
The trick to using penetrating oil is to attach a soaked rag to the part and let it sit overnight. I see people spray more and more on the bolt etc like it is going to build up or something, and it makes me cringe. Kroil is good but others are good too.
H60John
H60John
Oklahoma
Thank you all for the input
Update — turbo coolant leak resolved
Finally got the truck back after the dealer handled the driver-side (left) turbo coolant leak. Wanted to close the loop for anyone who finds this thread later.
I made a deal with the dealer thank god or would have had to try and sort it myself.
What it turned out to be: The leak was the left turbo plus the coolant fitting/lines on that side — confirmed on the invoice as “leaking coolant and oil found on back side of turbo, failed on turbo and fitting.” So it wasn’t just the turbo; the fitting/line side was involved too, which lines up with the external-leak diagnosis rather than a purely internal seal.
What they replaced:
  • Left turbocharger (Ford reman, part G1013)
  • Metal coolant bypass pipe behind the turbo
  • Both turbo coolant tubes (BL3Z-8A520-B x2, BL3Z-8K153-BB)
  • Coolant line O-ring (AA5Z-00815-C)
  • Oil line gasket (BL3Z-6N652-B) + turbo gasket (CL3Z-9450-B)
  • Line connectors (BL3Z-6A968 series)
  • Coolant refill
The part-ordering saga (heads up for anyone doing this job): This dragged out 3 weeks because the dealer kept getting the wrong turbo from Ford — four rounds. Turned out the replacements kept showing up with a mounting bracket/lug that the catalog photos showed as deleted. If you’ve read about the mid-2013 BorgWarner revision that removed the turbo mounting lug (“service turbos no longer require support brackets”), that revision mismatch is apparently still causing wrong-part deliveries. Worth confirming the exact supersession/prefix with your dealer’s parts dept against your VIN before they order, or you may hit the same loop.
No coolant leak on inspection at pickup. Small amount of oil residue near the turbo (assembly/pre-lube, stable over several hours — watching it over the next few days, but looks like normal residue).
