2016 Limited with 10 speaker Sony stereo...
Hershburglar
NC
What are the speaker sizes?
I know the center channel and rear pillars are 3.5” of I’m correct and the sub is an 8in.
I have seen different sizes listed for the front and rear doors. Just want to verify before purchasing all my replacement speakers. Thanks.
Mean_Dean
Lilburn, GA
You can use 5x7 or 6x8 in the doors. Recommend using Crutchfield.com to find and buy the ones that will fit. Or at least check the fit then look to see if you can find them cheaper. If you are using the factory amp make sure to get high efficiency model speakers, IE 91db.
Aspen03
Indianapolis
6x8 are the door sizes but as mentioned 5x7 works as does a 6.5 with an adapter if you want something different as their are considerably more choices available in that size or you wa t to do an improved component setup.
