2017 - Interior liftgate header replacement part?
Fasttimes
Miami
As just like in my 2010, this 2017 trim piece breaks its brackets when you pull it off the truck. I was replacing one of my blend door actuators I needed to remove this piece to move another trim piece and three of the four plastic brackets broke off.
I'm trying to source a replacement, but I can't find an exact part number. My part says part # 78515A40, but I can't find it. I do see similar parts but they have a different number listed for the truck, 7L1Z-7841308-AA.
Also, it's not clear as you see in the picture of the part if the plastic white trim parts which are seem to be glued to the tan plastic, as well as the foam padding will come on the new part.
Has anyone had to replace this part because I know it must break often when you remove this trim piece. What a pain in the butt.IMG_4909.jpegIMG_4908.jpegIMG_4912.jpegIMG_4911.jpeg
99WhiteC5Coupe
Have you tried to go to a Ford dealer part’s department with your VIN?
bloodhound
Merica
Has anyone had to replace this part because I know it must break often when you remove this trim piece. What a pain in the butt.View attachment 83310View attachment 83311View attachment 83312View attachment 83313
7L1Z-7841308-AA is the correct part number. This is what the replacement comes with
