2019 Liftgate
bbeville
Fort Myers Fl
I have a 2019 Platinum with a lift gate issue. At times the button on the dash, key fob and rear handle will not open the lift gate. It seems that it will work occasionally in the morning but rarely in the afternoon .
When it works in the morning it usually just works one time.. and then after setting it will work again .
Heat related ?? Any ideas ?
bmk1
yellville arkansas
Any luck? I have 2019 limited and I just all the sudden starting having issues.
Went to open it to load up and nothing. No matter if I press the button on gate, button at console, or the remote. You can tell it is not even trying.
After I got home and got kids unloaded went back outside to try it. Pressed the button on remote and it worked fine. Closed it and nothing again.
Went to console and tried turned power gate off and then button by console worked.
Closed gate and turned on power console. Nothing again now it won’t open. It tried like 3 times (making noise and moving) but it wouldn’t unlatch. Now it won’t do anything again.
It makes no sense bc there is no time or reason? It is not even trying to unlatch.
